Mahendra Rana
Mar 1, 2019 11:39 AM UTC
Is it SPBTLE-RF (BLE) module can directly communicate with laptop Bluetooth?
Is it SPBTLE-RF (BLE) module can directly communicate with laptop Bluetooth although I have customized serial port profile. I tired after paring with laptop Bluetooth in device manager it not show any com ports/virtual com port. Can any one suggest how I can communicate with laptop Bluetooth.
Is it any PC/Laptop tool available to communicate with BLE device.
Mahendra Rana
Mar 4, 2019 8:51 AM UTC
Is it anyone tried above?
Winfred LU
Mar 26, 2019 3:32 AM UTC
Hi Mahendra,
If you are trying to look for SPP (Serial Port Profile), it does not exist.
The SPP profile is for Bluetooth classic only.
If instead you are trying to have some proprietary profile, you need to implement that profile before to see it working.
From the results, it looks the BLE module worked well (it connected to the laptop successfully), but the profile was not implemented yet.
Thank you.
Best Regards,
Winfred
