Stabilo
Apr 7, 2020 4:22 PM UTC
Is it possible to set the agc to a fix value ?
I have a question about the BlueNRG2 device: is it possible to set the agc (automatic gain control) to a fix value ?
Maybe in the RADIO_CONFIG register ? But there is no info about the content of this register !
Thanks a lot !
Winfred LU
Apr 9, 2020 4:33 AM UTC
Are you trying to adjust the transmission power?
Please try to call the ACI: ACI_HAL_SET_TX_POWER_LEVEL()
Stabilo
StabiloAuthor
Apr 9, 2020 6:41 AM UTC
Not exactly. My transmission power is fix. But I would like to set the agc to a fix value.
I think agc allows to automatically control the gain of the signal at the reception. Then, the final RSSI (dBm) depends on a "raw" measured RSSI and on the agc. I would like to know if it is possible to fix this agc to a specific value.
On some other RF chips from ST, I saw that the agc can be enabled or disabled.
Note1: I am not using the ACI, I am implementing my code directly in the BlueNRG device.
Note2: I am not using BLE but only the Radio API.
