prabhu bhavikatti
Aug 16, 2017 10:29 AM UTC
in L9950 ic i am unable to control the out11 ic
Posted on August 16, 2017 at 12:29
in l9950 ic all output enabling and disabling exept out11 pin how can configure them.
    Ignazio Testoni
    Aug 31, 2017 12:42 PM UTC
    Posted on August 31, 2017 at 14:42
    Hi
    g.prabhu
    Controlling OUT11 is not different that controlling other HS output like OUT7 to OUT
    Please double check your SPI register configuration.
    Best Regards.
    Ignazio
    prabhu bhavikatti
    Sep 1, 2017 12:19 PM UTC
    Posted on September 01, 2017 at 12:19
    All other high side switches are working properly only out11 is not working properly i checked my time
    Prabhu
    Ignazio Testoni
    Sep 6, 2017 9:08 AM UTC
    Posted on September 06, 2017 at 11:08
    Hello Prabhu,
    once you have turned on OUT11, could you please read all register contents and provide it here?
    Thank you.
    Regards.
    Ignazio
    prabhu bhavikatti
    Sep 7, 2017 7:53 AM UTC
    Posted on September 07, 2017 at 07:53
    hi ignazio,
    If i make only out11 high then out11 will high.if i make it low should make enable bit as low.
    Thank you
    prabhu
    Ignazio Testoni
    Sep 8, 2017 12:10 AM UTC
    Posted on September 08, 2017 at 00:10
    I'm sorry Prabu,I don't understand really the problem.
    Is OUT11 working properly or not?
    Ignazio
