MGara.1
Apr 13, 2022 8:24 AM UTC
How to read the state of an output pin?
I'm using STM32L053 to send an SPI data to other compenet.
i don't know if the data has been send or not. I don't have an oscilloscope to see the signal.
what should i do to know if the data is sent correctly or not?
KnarfB
Apr 13, 2022 12:12 PM UTC
External USB logic analyzers start at $10. Or you build one using a FTDI chip https://sigrok.org/wiki/FTDI-LA.
You could read the SPI back by using a 2nd SPI port on the MCU. But even then, you cannot tell if the data on the wire is exactly as it should be.
hth
KnarfB
MGara.1
MGara.1Author
Apr 13, 2022 12:28 PM UTC
thank you knarfB,
