Andrea Ortogni
Jun 15, 2018 8:01 AM UTC
How to get the website certificate ?
Posted on June 15, 2018 at 10:01
Hi
i'm using a SPWF04Sa wifi module and i need to connect to a cloud using https (port 443)
There is a way to set the cloud's certificate without using AT+S.TLSCERT command ?
I mean : I don't want to set it manually if i change the cloud. So, there is an automatic way to set cloud's certificate and key ?
Thanks in advance !!!
#web #tls #certificate #https #spwf04sx
