mkuma.1
Oct 1, 2020 3:21 PM UTC
how to calculate blue nrg stack usage size.
I am using the BLUENRG-M2SP ble chip set , i created the 2 services ,there services are Primary Services 1. first service has the 3 characteristics and Second services has the 5 characteristics , if i add third services , i am getting Lack of Memory Error , Kindly help me out
how much memory utilized each characteristics. and service ,
    Winfred LU
    Oct 15, 2020 3:27 AM UTC
    After installing BlueNRG-1_2 DK package, an utility called BlueNRG-X Radio Initialization Parameters Wizard will be available for your easily generating config file, including the reserved memory size for your customized service and characteristics.
    Please refer to DK package:
    https://www.st.com/content/st_com/en/products/embedded-software/evaluation-tool-software/stsw-bluenrg1-dk.html
    and the document located at:
    file:///C:/Program%20Files%20(x86)/STMicroelectronics/BlueNRG-1_2%20DK%203.2.1/Docs/BLE_Radio_Parameters_Wizard/BLE_Radio_Parameters_Wizard.html
    mkuma.1
    mkuma.1Author
    Oct 16, 2020 1:37 PM UTC
    Thanks for hint , i will go through link.
