ANDRES RODRIGUEZ
Nov 5, 2018 10:11 PM UTC
Hi, Is there some document about PCB antenna design for the BLUE NRG-2? Thanks
alok
Nov 8, 2018 5:00 AM UTC
You can refer to following App Notes. The AN4819 talks about Balun layout etc
The device requires standard 2.4GHz Bluetooth Antenna
Refer to following documents
AN4819: PCB design guidelines for the BlueNRG-1 device
AN5187: BlueNRG-1, BlueNRG-2 improving robustness
ANDRES RODRIGUEZ
Nov 9, 2018 2:44 AM UTC
alok,
Thanks for your answer, the documents are very interesting and I'm going to check on them, but I need info about the the best PCB antenna design for the blue nrg, type, dimmension, pcb material, pcb thickness, etc.
Again, thanks.
ANDRÉS FELIPE
