AKuma.2074
Dec 6, 2019 10:33 AM UTC
Help to interfce X-NUCLEO-NFC01A1 with BlueNRG2
I m trying to interface X-NUCLEO-NFC01A1 with BlueNRG2. After googling around I found projects and codes for stm32 based nucleo boards, but couldn't find anything for BlueNRG2.
Can you provide me the project or source code for the same?
alok
Dec 19, 2019 5:32 AM UTC
Not aware of any ready example available for BlueNRG2 with X-NUCLEO-NFC01A1.
However, if you have STEVAL-IDB008V2
https://www.st.com/content/st_com/en/products/evaluation-tools/solution-evaluation-tools/communication-and-connectivity-solution-eval-boards/steval-idb008v2.html
You will notice there are Arduino UNO R3 compatible connectors are available. You can directly mount the X-NUCLEO-NFC01A1 on these connectors and re-use the sources available in "C" language available in X-CUBE-NFC1 here...
https://www.st.com/content/st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-nfc1.html
Please choose a suitable project from BlueNRG-2 and integrate these code. Hope it helps
