Oct 19, 2023 5:29 AM UTC
getting started with L9963e from Externel mcu for configuring the L9963e device & reading the values
hi all,
 i want to configure the L9963e Bms Ic from externel mcu and  i need to implement the communication to the BMS so that i can read read and write the register values i.e, vcells values etc .
Thank you
Nov 17, 2023 1:21 AM UTC
Hey @prathap_07  did you get any far with this? I am also trying to do this and I am unable to receive data from the L9963E.
May 29, 2025 9:52 AM UTC
Hi, did you solve this? Cause i also want to comunicate with an external MCU. If you solved you can help me?
