Philippe SIMONNET
frequently asked questions on ST S2-LP Sub-1Ghz transceiver
here is a post for wireless community (Sub-1Ghz solutions) to answer many frequently asked questions and good practices using ST S2-LP transceiver.
please find attached document to get additional information on this perfect Radio chipset.
Philippe
Cezar
Explorer II
April 18, 2026
@Philippe SIMONNET Can you link this document to the product's page?
Philippe SIMONNET
Hi Cezar,
wiki page is done, should be quickly available for community (under approval)
Philippe
Andrew Neil
@Philippe SIMONNET maybe pin this thread ?
Dear Mr. Simonnet,
We are currently using the newer STM32WL33 (M0+MRSubG) for a receiver-only application, and given that the transmitter is continuously transmitting (inserting stuffing bytes between well-formatted packets), we had to adapt the HAL code to a good extent.
I found this document and read with much attention the S2-LP recommendations.
Are this document still applicable (and to which extent) to the STM32WL33?
In particular, STM32WL33 has the "AFC3" register, which has no direct equivalent in S2-LP.
Thanks in advance,
Renzo Posega
Philippe SIMONNET
Hi Renzo,
S2-LP recommendations are more or less applicable to WL3x radio, even if :
- WL3x is RF SoC / S2-LP transceiver
- there are WL3x radio improvements, so register changes happen
regarding AFC, I can give you recommendations if you tell me Radio configuration you have to use (modulation, packet mode/direct mode, ...)
or you can also rich me entering support request here Online Support
(please mention my name, to route ticket to me as fast as possible)
thanks
Philippe
