KIMJIHOON
Oct 28, 2024 15:07 UTC
EVLKST8500GH-2 test envirionment
I am doing g3-PLC test by connecting two board of EVLKST8500GH-2
according to ST G3-Hybrid PLC&RF GUI Quick start guide, but i am not clear test envirionment
1) COM port of PC is connected with ST8500GH-MB or  NUCLEO-G070RB, when i connect with  NUCLEO-G070RB port is recognized but when i connect with ST8500GH-MB, port is not recognized in the PC.
2) I am using 30V(AC) power for Power line because " ST8500 Hybrid PLC&RF Connectivity Development Kit User
Manual"  Safety precautions guide of " The kit is intended for use on extra low voltage (ELV): <50 V AC, <75 V DC."
but i am not clear this 30V(AC) is enough for PLC. i want to know the level of Power
3) I want to know power line connection between two board EVLKST8500GH-2. serial or pallel ?
Didier HERROUIN
Didier HERROUINBest answer
Jul 7, 2026 09:35 UTC
I can see that the question is very old, I just provide an answer to close the point.
You will find most of the answers in the User Manual of the eval kit : https://www.st.com/resource/en/user_manual/um3244-evlkst8500gh2-getting-started-with-the-st8500-hybrid-plcrf-connectivity-development-kit-stmicroelectronics.pdf
The AC mains are not required for your communication tests in labs or for your FW tests, as a DC jack power supply is provided.
Then, the 2 boards can be connected by 2 wires (not powered).
Didier HERROUIN
