arnaud239955
Jul 17, 2016 10:35 AM UTC
ERROR: Unable to load CA certificate
Posted on July 17, 2016 at 12:35
Doing the Example 1 of the AN4683 (TLS Example 1, mutual auth), all commands work without problem (keys and certificate generation), same for imports in Wifi module (send back ''OK'')
But the last command : AT+S.SOCKON=ipaddress,443,s returns ''ERROR: Unable to load CA certificate'' (of course ipaddress is the ip address of my TLS server)
I have several questions :
- Is the CA certificate checked during import in the module ? According to my test, the certificate is not checked during import (could you confirm ?)
- Is the example given in the doc works for you ?
- Any clue ?
Thanks a lot
Zirco
    arnaud239955
    Jul 21, 2016 7:27 AM UTC
    Posted on July 21, 2016 at 09:27
    Thank you Gerardo, I checked the two threads.
    In fact, the loading was incorrect due to way I did it.
    I use gtkterm on LInux and did the import by a cut/past of the PEM text. In fact, it's mandatory to use the menu ''send raw file'' to import the certificate.
    Zirco
