Nandy K
Mar 3, 2016 8:34 AM UTC
Error : Command not found
Posted on March 03, 2016 at 09:34
Hai !
I am having two wifi modules and I have configured the initial settings.
In both the modules I am getting the status ''Handshake Complete''.
After this i tried to give command ''AT'' and both giving the response OK
now I have sent the command ''AT+S.SOCKD=8855'' only one module responds OK and the other now is showing ''ERROR: Command not found''.
Could you please help me why it is so?
Also tell me how to update the firmware through cable
    Gerardo GALLUCCI
    Mar 3, 2016 12:35 PM UTC
    Posted on March 03, 2016 at 13:35
    ''command not found'' means the module contains an old FW version (use FW3.5 on both of them), or provided command was not properly formatted (check string).
    About the UART update, take a look at the hands-on manual.
    Nandy K
    Nandy KAuthor
    Mar 3, 2016 2:10 PM UTC
    Posted on March 03, 2016 at 15:10
    Hi
    Thank you  I have updated the firmware V 3.4 but could you please tell me where i can find the latest firmware version.
    I searched on the ST website but couldn't find it :(
    Gerardo GALLUCCI
    Mar 3, 2016 2:14 PM UTC
    Posted on March 03, 2016 at 15:14
    http://www.st.com/wifimodules
