BMoha.19
May 5, 2020 11:28 AM UTC
Enable disable LDC mode
I really appreciate the reactivity of the forum, thanks a lot.
i have some questions:
1- When i enable/disable LDC mode using S2LPTimerLdcrMode, and S2LpTimerFastRxTermTimer, i need to run command S2LPCmdStrobeReady and S2LPCmdStrobeRx after each enable and disable?
2- When i have TX_FIFO_ERROR, i need only to run S2LPCmdStrobeFlushTxFifo, S2LPCmdStrobeReady, S2LPCmdStrobeRx (last two command to prepare S2LP fo RX)?
3- Sometime i have IRQ status 0.0.0.0 what does't mean? Is't a problem of collision, because i see this problem when S2LP try to send message and a new message is received?
4- when i use mechanism of Infinite preamble as described in application note Sniff Mode application (and my chip is also in LDC mode) how i will be sure that the receiver will be wakeup? in other word, how i will be sure that my msg (not the msg of infinite preamble but the real msg) will be in the Fast RX timer of the receiver?
Thanks in advance.
Sergio ROSSI
May 12, 2020 5:29 PM UTC
Please open a ticket using https://my.st.com/ols
We'll move from there
