Senior
Apr 5, 2023 6:07 AM UTC
Drivers to configure BLUENRG-2N
is the drivers to configure BLUENRG-2 and BLUENRG-2N are the same ?
can i use the same driver from x-cube-ble2 to make an application with BLUENRG-2N ?
Thank you.
ChahinezC
ChahinezCBest answer
Apr 5, 2023 2:26 PM UTC
Hello @malarab​,
I am not a BlueNRG expert, but you can check the BLUENRG-2 AND BLUENRG-2N document.
Regards,
Chahinez.
ChahinezC
Hello @malarab​,
Regards,
Chahinez.
malarabAuthor
Senior
Apr 12, 2023 9:40 AM UTC
hi @ChahinezC​
it is not clear in the documentation,
i already started the implementation but it is not working yet !
I don't know if it can be a problem in the compatibility of the driver with the hardware.
Thank you,
