May 21, 2026 14:54 UTC
Does the ST67W611M1 -m with PCB antenna have an rf switch
Does the ST67W611M1  (-B version) with PCB antenna have a built in rf switch? We want to programmatically or via pins switch between the PCB antenna and an external antenna.
TarikAbBest answer
May 22, 2026 07:34 UTC
Hi @Nkh
There is no internal switch in the module. The connector on the B version already includes a switch; however, this connector is intended for conducted RF measurements, not for connecting a second antenna.
The P version is designed for use with two antennas.
Regards,
TarikAbBest answer
Hi @Nkh
Regards,
