VKolo
Aug 13, 2018 12:37 PM UTC
Cannot to use BlueNRG-1 with internal 32 kHz oscillator.
If I changed the definition LS_SOURCE=LS_SOURCE_INTERNAL_RO, the procedure DeviceConfiguration() stopped in line "while(CKGEN_BLE->CLK32K_IT == 0);"
It seems that the internal generator 32 kHz does not work.
How I can to turn on generator 32 kHz.
    Winfred LU
    Aug 14, 2018 9:05 AM UTC
    Hi MicroLine,
    I've just tested again and
    It works for me normally.
    Could you please try STEVAL-IDB007V1 or V2 with the latest DK (v3.0.0)
    https://www.st.com/content/st_com/en/products/embedded-software/evaluation-tool-software/stsw-bluenrg1-dk.html
    and modify project Options | C/C++ Compiler | Defined symbols, then set
    Thank you.
    Best Regards,
    Winfred
