FSkro.1
Jun 11, 2021 9:10 PM UTC
Can't connect to STM32H7 on SEGGER or JLink
I can't connect to STM32H7B3I on SEGGER or using JLink. Resetting option bytes on JLinkSTM32 fails. If there is somehow irreparable damage, could that have been due to me programming high or low frequencies (1-400 MHz) in the RCC? If not, what could be the cause?
    Jun 11, 2021 9:27 PM UTC
    Posted to wrong subforum.
    Try power cycling the H7 with the BOOT0 pin pulled/strapped high, and then try connecting. And mass erasing the flash.
    I​f that recovers the part look at the VOS and LDO/SMPS settings in your code.
    Connection under reset requires NRST to be wired​ on the debug header.
    FSkro.1
    FSkro.1Author
    Jun 11, 2021 9:56 PM UTC
    Thanks. Where can I find the boot0 pin on my model?
    Jun 11, 2021 10:00 PM UTC
    Don't know what board and connections you have. The data sheet would enumerate the pins.
