Anup Kumar Das
Mar 18, 2019 7:06 AM UTC
Can i build a L2CAP channel using "LE Credit Based Connection request" signalling command in X-NUCLEO-IDB05A1?
Hello Experts,
I am looking to establish a L2CAP "CONNECTION-ORIENTED CHANNELS IN LE CREDIT
BASED FLOW CONTROL MODE" using "LE Credit Based Connection request" signalling command.
I am using two X-NUCLEO-IDB05A1 boards to build the connection.
After I send the command I don't get any HCI response.
Can anyone confirm if I can build such channel in X-NUCLEO-IDB05A1 device?
Below you can find the bare metal code as en example.
Thanks in advance,
AKD
