AElgh
Feb 2, 2024 6:38 PM UTC
Bug in the BLESensor-App(X-Nucleo-BNRG2A1)
Hello, i used the CubeMX to generate the example code for the X-Nucleo-BNRG2A1 board. The Example works well when the #define USE_BUTTON (0) :
However, when #define USE_BUTTON (1) I get the following blank page:
I've had the same behavior before updating the Firmware of the Module and after.
Thank you
Amir
