MCV.1
Jan 5, 2021 11:41 AM UTC
BlueNrg2M2sp Invalid HCI Command
Hi i am using Bluenrg 2 m2sp as network processor mode , Here when i sent aci_gatt_update_char_value_ext command , some times i getting getting invalid command response . may know the reason , if i get invalid response , shall i retry same command once .
Regrds
Manukumar
    Winfred LU
    Jan 12, 2021 5:28 AM UTC
    I think those might be Invalid HCI Command Parameters (code 0x12).
    Please check the differences between successful and failing commands. Possibly some parameters were incorrectly configured for the failing cases.
    MCV.1
    MCV.1Author
    Jan 30, 2021 6:59 AM UTC
    Thanks Winifred your response , i will check which command parameter are incorrect during the response
