cun3
Jun 15, 2014 4:16 AM UTC
blueNRG USB Dongle Dev Kit Chip Antenna
Posted on June 15, 2014 at 06:16
I'm in the process of replicating the bluetooth radio design in on pg. 37 here:
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00099259.pdf
, and I'm having difficulty locating the AN2051-254 2.4GHz bluetooth chip antenna used in the design.
Other than contacting the antenna manufacturer (
http://www.rainsun.com
) in Taiwan I think, does anyone have any tips relating to how I can source the chip antenna used in the design or know of a similar antenna that has worked with the dev. kit schematic.
Since I have limited access to the kind of equipment I'll need to tune an optimized matching network, I'm trying to minimize the number of variables required to design a functional circuit.
Thanks.
#bluenrg
marchese.graziella
Jun 16, 2014 2:21 PM UTC
Posted on June 16, 2014 at 16:21
At the following link:
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM00024648.pdf?s_searchtype=keyword
you can download the application note ''
Low cost PCB antenna for 2.4GHz radio''.
regards,
Graziella
