mickael2
Mar 29, 2018 5:19 PM UTC
BlueNRG-MS OTA
Posted on March 29, 2018 at 19:19
I'm trying to figure out whether it is possible or not to upgrade the firmware of a host processor connected to BlueNRG-MS.
From this
http://www.st.com/en/embedded-software/st-blue-dfu.html
it seems possible:
'The ST BlueDFU app allows WeSU (STEVAL-WESU1) boards to receive firmware images over-the-air from a smartphone and write them to the STM32L151 Flash memory.'
There is even an application note dedicated to this :
http://www.st.com/content/ccc/resource/technical/document/application_note/09/45/83/e0/7d/67/46/2c/DM00115333.pdf/files/DM00115333.pdf/jcr:content/translations/en.DM00115333.pdf
But when digging in the code of STEVAL-WESU1 or X-CUBE-BLE I couldn't find where and how it is implemented.
I would like to adapt it to make the firmware of the module CMWX1ZZABZ-091 upgradeable from ble.
By the way I couldn't find the source code of ST_BLUE_DFU app. Is it possible to get it somewhere? The only feature I want to use from bluetooth is the OTA.
Thank you
Best Regards,
    mickael2
    mickael2Best answer
    Mar 30, 2018 9:37 AM UTC
    Posted on March 30, 2018 at 11:37
    I found the source code for firmware OTA it is bundled with the executable (not very convenient with linux)
    http://www.st.com/en/embedded-software/stsw-bluenrg-dk.html
    I opened a new thread for
      application source code
    https://community.st.com/0D50X00009XkgRYSAZ
    Best regards,
    mickael2
    mickael2AuthorBest answer
    Best regards,
