May 25, 2016 12:08 PM UTC
BlueNRG-MS image structure
- 2 replies
- 1017 views
Posted on May 25, 2016 at 14:08
original image (bluenrg_7_1_e_Mode_2-32MHz-XO32K_4M.img)
Could you explain this moment Regards, Andrei Kukenov bluenrg image bluenrg-ms
Please help to clarify the following... I would like to do script to merge image file with required ifr config. To check my tools I have used ''bluenrg_img_converter.exe'' converter provided ST. So I have found that this converter distorts four bytes of the original firmware (b'BLUE' -> b'FFFFFFFF'') because original image realy has 'BLUE' on this place.
