KHuan.9
Oct 15, 2019 10:21 AM UTC
BlueNRG-MS How to fix unhandled event 16
Hi, I'm using NUCLEO-F401RE+X-NUCLEO-IDB05A1 as a central.
After start scan, I got unhandled event 16.
Is 16 = EVT_BLUE_GAP_ADDR_NOT_RESOLVED_BIT?
How should i fix it? or what may i set wrong?
Bluetooth firmware is bluenrg_7_2_c_Mode_2-16MHz-XO32K_4M
and
const IFR_config_TypeDef IFR_config = {
 /* Cold table */
 0x02,0x3A,0x40,0x02,
 0x34,0x1B,0x02,0x39,
 0xA2,0x02,0x3C,0x20,
 0x00,0xFF,0xFF,0xFF,
 0xFF,0xFF,0xFF,0xFF,
 /* Hot table */
 0x02,0x1C,0x43,0x02,
 0x20,0xEC,0x02,0x1F,
 0xAF,0x00,0xFF,0xFF,
 0x02, /* Stack mode = Mode 3, RAM1+RAM2 (8 connections) */
 0xFF, /* GPIO config = Disabled */
 0xFF,0xFF,
 /* Reserved section */
 0xFFFFFFFF,
 0xFFFFFFFF,
 0xFFFFFFFF,
 htobl(0xFFFFFFFF), /* Max connection event time = 4000 ms */
 htobl(0xFFFFFFFF), /* LS crystal period */
 htobl(0xFFFFFFFF), /* LS crystal frequency autocalibration*/
 htobs(0x01F4), /* Slave SCA = 500 ppm */
 0x00, /* Master SCA = 500 ppm */
 0xFF,
 htobs(0x0148), /* HS startup time = 800 us */
 0xFF,0xFF,
 htobl(0xFFFFFFFF), /* UID */
 0xFF,
 0x16,0x06,0x13,/* Year/Month/Day in BCD. */
 /* Free section (user data) */
 htobl(0xFFFFFFFF),
 htobl(0xFFFFFFFF),
 htobl(0xFFFFFFFF),
 htobl(0xFFFFFFFF),
 htobl(0xFFFFFFFF),
Thanks for any answer or advice~
Sincerely,
Kirby
