GGeor.10
Aug 14, 2018 6:20 AM UTC
BlueNRG-MS. Do not work "scan response" after one day working
So, After a couple days working. BlueNRG-MS do not answer on "scan request". All other functions work, i can connect/disconnect, write/read gatt properties... I work with Aci_Gap_Set_Discoverable. I found only one case for resolving. It is reboot. It is bad solution.
    Scott Löhr
    Senior III
    Aug 14, 2018 10:23 PM UTC
    Can you give a more detailed description - if you cannot initiate a scan request, how can you connect? Which API is called exactly, etc.?
