CHoul.1
Nov 26, 2021 7:01 PM UTC
BLUENRG-M2SP schematic
I need the BLUENRG-M2SP schematic to qualify the application with the STmicro electronics library.
I need to configure the mode of the AC/DC converter. The spec sheet is not documented enough. With the schematics, I will understand what I need.
    Laurent LOUAZON
    Dec 1, 2021 9:12 AM UTC
    I would usggest to look at BlueNRG-2 datasheet.
    BlueNRG-2 is the SOC embedded inside BlueNRG-M2.
    Pins 1 and 2 of BlueNRG-M2 module are connected directly to pin 15 and 16 of BlueNRG-232 inside the module.
    BlueNRG-2 datasheet is providing detail on ADC use.
    Laurent
    CHoul.1
    CHoul.1Author
    Dec 2, 2021 11:29 PM UTC
    Hey Laurent,
    Thanks for your kind response, this is helping us :)
