May 25, 2025 8:52 PM UTC
BlueNRG-M2SA: DIO0 & DIO1 output problem
I'm trying to configure DIO1 and DIO0 as outputs in my custom board, but I can't get them to work. I'm using this basic code to test:
SysCtrl_PeripheralClockCmd(CLOCK_PERIPH_GPIO, ENABLE);
GPIO_InitOutputPinx(GPIO_Pin_6);
GPIO_SetBits(GPIO_Pin_6); // Sets DIO6 high correctly
However
GPIO_InitOutputPinx(GPIO_Pin_1);
GPIO_SetBits(GPIO_Pin_1); // Does nothing
Same thing happens with GPIO_Pin_0, but just with 0 & 1 (module pins 15 & 18). No high load that could tie to ground or draw a lot of current on these pins.
Could you please help?
Thanks.
