attemptx
Jun 18, 2020 7:13 PM UTC
BlueNRG-M2 no SPI signals
I am currently working with a BlueNRG-M2 module and STM32L433CC. I am unfortunately struggling right at the beginning.....
I tried the example codes generated with CubeMX but nothing worked.
So I tried to write my own code in a test project with FreeRTOS.
First I call the hci_init(); function and everything seems to be executed as it should from what I could observe through debugging.
Then hci_reset(); follows to reset the module and nothing appears on the SPI lines.
I have read in this forum that hci_send_req(); should communicate through SPI with the module and then wait for an event, but nothing is happening.
Does anyone have an idea?
I followed all the "Getting Started" documentations with step-by-step guide for CubeMX but it won't work.
An answer would be appreciated.
Best regards
Clément
