DLoza.2
May 5, 2022 11:11 AM UTC
BlueNRG-LP hci_le_advertising_report_event() isn't called
I want to program a connectionless observer to scan events, but the hci_le_advertising_report_event() callback isn't called.
I have followed the steps of programming manual PM0269 for configure the modular configurations to work as Broadcaster + Observer only:
  1. Define BLE_STACK_CUSTOM_CONF in the preprocessor.
  2. Enable CONTROLLER_MASTER_ENABLED in custom_ble_stack_config.h
  3. Set in asci_gap_init() GAP_BROADCASTER_ROLE|GAP_OBSERVER_ROLE roles
My enable scan with this configuration:
aci_gap_set_scan_configuration ( DUPLICATE_FILTER_DISABLED,
              ADV_NO_WHITE_LIST_USE,
LE_1M_PHY_BIT,
  PASSIVE_SCAN,
  0x10,
  0x10
hci_le_set_scan_enable(1,0);
I don't get any error, but the hci_le_advertising_report_event() isn't called. Supposedly, hci_le_set_event_mask( ) isn't necessary because the adv report event is enabled by default, but even calling this function, the callback isn't work.
I would like know what I'm doing worng.
Daniel
    Sebastien DENOUAL
    May 5, 2022 12:11 PM UTC
    Hi @DLoza.2​ ,
    After you rcall to aci_gap_set_scan_configuration ( ..);
    May you try to call aci_gap_start_procedure() instead of hci_le_set_scan_enable() ?
    Thanks,
    Sebastien.
    Sebastien DENOUAL
    Hi @DLoza.2​ ,
    Thanks,
    Sebastien.
    DLoza.2
    DLoza.2Author
    May 6, 2022 7:08 AM UTC
    Hi again @Sebastien DENOUAL​ ,
    Using aci_gap_start_procedure() instead of hci_le_set_scan_enable() works! I proved it before but It didn't work, maybe I configured it wrong.
    Thanks Sebastien!
    Daniel
