LTrin.1
Aug 9, 2022 3:04 PM UTC
BLUENRG-LP custom project issues
Hello there
I have a custom board based on STEVAL-IDB011V2 EVM. Is the same schematic but I have a problem with this. Apparently it boots but not run...
When I flash "Hello World" example I have some issue that I can't check why.... The expected message does not is sent complete. So I have this output:
0693W00000QNJIdQAP.pngIn this test, I reset the board sometimes. Some times it shows "Applicat", "Applicati", (Probably bootloader output?) Some times it shows truncated "Hello World".
I checked voltage levels by https://www.st.com/resource/en/application_note/an5503-bringing-up-the-bluenrglp-bluenrglps-devices-stmicroelectronics.pdf application note (bringing up the bluenrglp devices).
I tried the Power Supply test (flashing DTM Firmware - UART without update) and VDDA thats we expect 1.2V, I measured 0V. The Core voltage (VCAP) I measured 1.2V as expected.
I also tried flash other firmware examples without success.
Can someone help me?
    Laurent LOUAZON
    Laurent LOUAZONBest answer
    Aug 18, 2022 7:53 AM UTC
    I just replied to your message.
    I guess the problem was related to 22nH used for SMPS instead of 10uH (22nH is optional and can helps in sensitivity performances - "killing" the SMPS spurious).
    Please confirm.
    Laurent
    Laurent LOUAZON
    Aug 17, 2022 7:31 AM UTC
    Could you share your schematics and associated Bill of material?
    Laurent
    LTrin.1
    LTrin.1Author
    Aug 17, 2022 8:51 PM UTC
    Hello there
    Please see you message inbox. I sent to you.
    Regards,
    Leonardo Trinta
    Laurent LOUAZON
    Please confirm.
    Laurent
    LTrin.1
    LTrin.1Author
    Aug 18, 2022 1:29 PM UTC
    Hello there
    Yes, was it that's what caused the issue. Sorry for inconvenience.
    As suggestion, clarify it in EVM schematic.
    Thank you
    Regards,
    Leonardo
