aj.sk
Mar 7, 2019 9:18 AM UTC
BlueNRG evt_gatt_attr_notification->attr_value leading zero bytes
I cannot find any related information for this.
It seems like evt_gatt_attr_notification->attr_value always has 2 bytes leading zeros.
This means if a write a char value with Attribute_Val_Length = 0x02 and Attribute_Val = 0xCAFE I get a attr_value of e.g. 0x04FF1D010C01081800020000FECA
Where are these two bytes between the correct event_data_length and the attr_value coming from?
    rdscliff
    Mar 19, 2019 4:31 AM UTC
    Could it be the Offset field?
    aj.sk
    aj.skAuthor
    Mar 19, 2019 7:08 AM UTC
    If there is an offset field then it might well be it yes... will check
