kukushonok
Feb 18, 2015 11:32 AM UTC
BlueNRG discovery (scan interval) issue
Posted on February 18, 2015 at 12:32
I have some troubles while discovering ble devices:
no matter
what
I set
the interval
scanning (to aci_gap_start_general_discovery_proc function) procedure
lasts
10 seconds
Can I
somehow
reduce the duration of
the scan
Regards,
Andrei Kukenov
marchese.graziella
Feb 19, 2015 11:10 AM UTC
Posted on February 19, 2015 at 12:10
Hi Andrei,
the aci_gap_start_general_discovery_proc procedure is terminated when the procedure Aci_Gap_Terminate_Gap_Procedure with the procedure code set to 0x02 is send or a timeout happens (10.24 seconds).
 Therefore if you want to reduce the scan procedure, you can send  the Aci_Gap_Terminate_Gap_Procedure with the procedure code set to 0x02.
Regards,
Graziella Marchese
kukushonok
Feb 19, 2015 12:05 PM UTC
Posted on February 19, 2015 at 13:05
Hi, Marchese
Thacks a lot for your quick reply!!!
Regards,
 Andrei Kukenov
