MCV.1
Apr 22, 2021 7:15 AM UTC
ble not advertising after crashing ST BLE sensor app and disable enabling mobile BLE adapter
HI all
I am using blurenrg2 m2spa blue tooth chip . Its operates as a network mode . it communicating with host controller through UART 115200 baud rate . here i configured chip as peripheral role and st ble sensor app acts as a central device , when i mobile ble adapter is disable and enable , its failing advertise and even the sensor app forcefully crashes its failing adverting. how to resolve this issue , when i do normal connect and disconnect its working fine .
i used the below api , check link status
aci_hal_get_link_status ()
after app crashing and ble mobile adapter disabled , its always give the information , its connected as slave role .
can any one suggest how to solve this issue .
