Rick V
May 2, 2018 6:11 PM UTC
BLE Android Apps
Posted on May 02, 2018 at 20:11
Where can I find the source code for the Demo Android Apps, such as the 'BlueNRG' app or 'STM32 BLE Profiles' app.
Thanks,
Ricardo
#android-app #bluetooth
Antonio Vilei
May 8, 2018 2:09 PM UTC
Posted on May 08, 2018 at 16:09
Hi Ricardo,
the source code for the apps that you mentioned is not available. Anyway, on GitHub you can find our general purpose Software Development Kit, called
https://github.com/STMicroelectronics-CentralLabs/BlueSTSDK_Android
, that can be used as a starting point for smartphone app development. It is
a multi-platform library (Android and iOS supported) that permits easy access to the data exported by Bluetooth Low Energy (BLE) devices.
Best regards,
Antonio
Jess Walt
Jul 4, 2018 2:48 AM UTC
Posted on July 04, 2018 at 02:48
Thank you, Antonio, this helps me out and I have a question.
Where would I find an Android App programmer that would understand how to use the
multi-platform library you shared?
I have my app completed, all I need is for someone to use the code you shared above, so I can switch from using the phones internal Accelerometer and Microphone, to the SensorTile's Accelerometer and Microphone. With the code you provided it shouldn’t take a seasoned programmer long to do.
Thanks again,
Jess
Antonio Vilei
Jul 4, 2018 11:23 AM UTC
Posted on July 04, 2018 at 11:23
Hi Jess,
unfortunately, I don't have any contacts in your area.
As a start, you could try using some websites for freelance programmers. Or you could get in touch with some local Computer Science faculties to find students/interns with the programming skills you need.
Best regards,
Antonio
