milind2
Jan 7, 2017 7:54 AM UTC
aci_gatt_update_char_value fails
Posted on January 07, 2017 at 08:54
The function aci_gatt_update_char_value fails initially....and if fails there is while(1) loop...so system stuck here....what is issue ? after debugging it observed that function returns BLE_STATUS_TIMEOUT.....can you suggest solution for issue
    Oliver Beirne
    Jan 9, 2017 9:50 AM UTC
    Posted on January 09, 2017 at 10:50
    Hello
    We have forums setup to ask questions which you can see from the forums menu at the top of this page. Which ST product are you working with?
    milind2
    milind2Author
    Jan 9, 2017 10:55 AM UTC
    Posted on January 09, 2017 at 10:55
    We are using Bluetooth module BlueNRG-MS
    Oliver Beirne
    Jan 9, 2017 12:11 PM UTC
    Antonio Vilei
    Jan 10, 2017 11:05 AM UTC
    Posted on January 10, 2017 at 12:05
    I replied to this question here:
    https://community.st.com/0D50X00009XkeiRSAR
