When is the new VL53L7 going to be released?
And what does it do?
LCora.1
September 26, 2022
would be go to have it soonest
John E KVAM
The VL53L7 is almost out. The datasheet is up on the website, and you can go to Mouser and Digikey and enter a pre-order.
The L7 is exactly like the L5 - but the FoV has been widened. Instead of a 45 degree prymid of light, you get a 61 degree FoV. This will lower the distance one can range as the light disapates with distance, but one can still see people to a good 2 Meters.
It would be perfect to detect people as they approach.
The big announcement is scheduled for Oct 4th, and parts will be avalible shortly after that.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
