chipmc
What cover lens should I use with the VL53L5CX?
There is no mention in the data sheet as there is with the VL53L1X. I am currently using this cover from Hornix - would it work here as well?
John E KVAM
no - you want the
Hornix – IR109C0-IC09-A066
Same idea - different size as the L5 is larger
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
