October 3, 2023
VL6180X sensor initialization SR03 setting
Hi, I was wondering what is the SR03 settings in initialization of VL6180X ToF sensor? I had gone through the user manual & application note AN4545 but i couldn't get the answer. If someone knows please explain. It just for educational purpose only.
Thanks in Advance,
AK.
Anne BIGOT
During the initialization phase, some registers are configured in order to put the sensor in a state that will give the better ranging results. The recommended settings required to be loaded onto the VL6180X during the
initialization of the device is this "Standard Ranging (SR)" configuration defined in section 9 of the AN4545.
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised. ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
