Aug 19, 2026 12:34 PM UTC
VL53L9CX – Optical Filter and Power Supply Noise Requirements
Could you please share the detailed optical filter characteristics of the filter integrated in front of the VL53L9CX receiving sensor, including its spectral transmission/response characteristics?
Also, I would like to understand the power supply noise sensitivity of the sensor. Could you please provide the acceptable input voltage deviation, ripple, and noise limits for the sensor's power supplies?
MeganeG
MeganeGBest answer
Sep 15, 2026 7:45 AM UTC
Hello ​@Elbin,
The optical filter characteristics can be found in the datasheet DS14879, in the 2.4 Bandpass filter section - table 5.
For the power supply noise, you can find all the information in the 2.10 Power management section - table 8. It specifies the acceptable tolerances for the power rails. Please make sure that the voltage always remains within these limits.
Let us know if it answers your questions.
Thanks, Megane
ElbinAuthor
Aug 24, 2026 11:21 AM UTC
Hi Team,
Gentle reminder on the request. Could you please help us with your recommendation?
Thanks,
Elbin
MeganeG
MeganeGBest answer
Hello ​@Elbin,
Thanks, Megane
