Apr 22, 2025 7:28 AM UTC
VL53L8CX RUNNING SPD
Hello, I have a problem when I try to run the SPD code under STM32cube IDE, I have this under the serial monitor which remains stuck like this:
SPD ULD SW Kit version 1.0.0
Module type = VL53L8CX
Module ID : 0000000000000000_VL53L8CBV0GC/1$2
FW Version : 1.7.0.0
ULD Driver VL53LMZ_2.0.10
SPD Initialize SPD
Oct 22, 2025 7:12 AM UTC
can you confirm the commands are working? You can try the "help". (the command manager is described in the User Guide, slide 15)
Are you using the P-NUCLEO-53L8A1 boards ?
Thanks,
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised. ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
