I'm going to guess you are using a coverglass. Below about 60cm the glass return signature gets mixed in with the target signature and a million photons from your glass at distance zero, mixed with a million photons from your target at distance 50cm = 25cm.
Having lots of photons - from a white paper will overwhelm the glass and you get closer to the right answer.
Solution is to remove the coverglass, get a better one, or calibrate the one you have.
You can read my article on the subject - it's short.
https://community.st.com/t5/mems-and-sensors/time-of-flight-cover-glass/ta-p/49259
This is the user manual on how to calibrate.
https://www.st.com/resource/en/user_manual/um3109-a-guide-for-using-the-vl53l8cx-lowpower-highperformance-timeofflight-multizone-ranging-sensor-stmicroelectronics.pdf
Product – 閎喬光學 - is a Taiwanese company that sells a really good coverglass. (It's not associated with ST, but we did jointly design that glass.)
- john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
