GRama.2
VL53L5CX Target Order Values
  • June 22, 2023
  • 1 reply
  • 1042 views
When I use vl53l5cx_get_target_order, it returns 2.
I assume there are only two values (1 & 2). Does 2 = CLOSEST or Strongest?
Thanks.
Giri
Best answer by Anne BIGOT
Hello
Here are the meaning of the values :
1 = CLOSEST, 2 = STRONGEST
Anne BIGOT
Anne BIGOTBest answer
Hello
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised. ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
