VL53L1X using with another laser source
I had a query regarding the VL53L0X TOF sensor. Is it possible to block the laser on the board and use an off board laser of same wavelength and get readings from TOF sensor? such as intensity readings only?
RiturajBest answer
Senior
August 10, 2024
Technically , It should. ONly if you block it completely or it would just face interference and distornt results
RiturajBest answer
Senior
August 10, 2024
vishnusfAuthor
Thank you for the response. I appreciate it.
