I'm truly sorry I missed this post. Hopefully you have solved your problem without a response.
But for those who might see your post, a response is required.
The fact that you can read the Chip ID is sufficient to know the sensor is booted.
The system status has two bits.
[1]
firmware_first_range: FW first range status
[0]
firmware_bootup: FW initial boot status, Set by FW after completing initial coldboot. if 0 carry out intial boot sequence, if 1 carry out secondary boot
So bit 0 (the LSB) is set after a cold boot.
And bit 1 say's that you've completed at least one range.
My guess is that you have ranged, then rebooted your system without powering down the sensor.
So, it's still ready to go. It never noticed the reboot of your system. It's just waiting for another 'go' command.
if you power down the sensor and then power back up, you will see the register go from 2 to 1.
- john
- john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
