Visitor
Nov 23, 2026 1:52 AM UTC
VL53L1X Measurement Issue for Water Softener Salt Level
As shown in the figure above, we are using the VL53L1X to measure the height of salt blocks in a water softener, and have observed the following phenomena:
1. The measured height is 5 cm more than the actual value.
2. In a white plastic salt tank, the measured salt height is 7–9 cm more than the actual value near the light-transmitting areas close to the outer shell.
3. In a black plastic salt tank, the measured salt height is 5 cm more than the actual value.
Why is this happening?
Andrew Neil
Nov 23, 2026 10:16 AM UTC
Welcome to the forum
Please see How to write your question to maximize your chances to find a solution for best results.
Please describe how, exactly, you are “using” the VL53L1X - some good, clear photos of your setup would help.
Do you get accurate results in other situations?
YESHU306Author
Visitor
Nov 23, 2026 10:36 AM UTC
Measuring the ground or desktop, the height measurement is correct, but when measuring the salt surface, the measured value is 4–5 cm more than the actual distance.
YESHU306Author
Visitor
Nov 23, 2026 10:43 AM UTC
        The sensor outputs 10 cm.
The sensor outputs 14 cm.
