VL53L1X Duribility
I have been testing with the VL53L1X TOF sensor and am curious on the durability of the sensor in rugged environments. Such places would look like an industrial environment where vibration and impacts in inevitable. The sensor PCB would be potted and fully enclosed in a containment box. However, an opinion by others on how it would fare would be greatly appreciated. I know the data sheet shows shock as being an issue.
Thanks!
John E KVAM
John E KVAMBest answer
The easy way to express our durability is to brag that we have sold over 2 Billion VCSEL-based sensors with the vast majority going into the cell-phone markets. I don't think too many electronics devices get dropped as often as cell-phones do.
We did do some Failure-in-Time analysis, but I don't think the statistics work out very well unless you have at least one failure when you over-heat and over-voltage the parts and run thousands of them for weeks and weeks.
We got no failures and the result of the analysis came out to several thousand years, and that's crazy.
Unless someone's life is at stake, I wouldn't worry about it.
- john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
John E KVAM
- john
