November 27, 2024
VL53L1CB calibration functions
Hello ST team.
I am operating the VL53L1CB sensor with zephyrRTOS, I reach distances to four meters without problems, in addition to measure distance above them (eight meters top in ideal conditions), all this in ROI.
I am working with the manual UM2133 and I have doubts about the calibration, I have a crystal covers (bought by aliexpress) and I did the calibration proposed by the manual, it has some crosstalk interference, it works with intermediate accuracy and precision.
Do you have any manual that explains in more detail about the calibration (refSPAD, crosstalk, offset)? especially the point “6.2.6 Setting crosstalk calibration data” that makes in detail the parameters and how it affects the sensor.
The purpose is to improve accuracy and precision
Best regards
Thanks!
John E KVAM
John E KVAMBest answer
the best info on crosstalk is
https://community.st.com/t5/mems-and-sensors/time-of-flight-cover-glass/ta-p/49259
It's short, but it references a couple longer, more in-depth documents.
Give that a read and see if it explains enough for you.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
John E KVAM
