JSaun.1
VD56G3 collateral available?
VD56G3 template driver would be useful but also a spec for the registersets, som programming information, etc.
Id like to evaluate thius device for future use using a driver that I cna run from various linux environments.
Is ther a doc for programming?
Is there ANY collateral availible for getting a jump writing a driver for this device? HW Spec, template driver, programmers guide, etc...
Thanks in advance!
JSaun.1
JSaun.1Author
JSaun.1
JSaun.1Author
Still is there a programmer guide? A description of the interface registers, etc???
April 24, 2023
Probably only to qualified customers, under NDA.
Would suggest you engage with the authors of the aforementioned GitHub code, they can perhaps better guide you to the individuals or sales contacts you need to work through.
Dupe https://community.st.com/s/question/0D53W00002EjX41SAF/vd56g3-programmers-guide-is-this-availible-also-the-hardware-interface-description-documentation-also-is-there-a-dev-kit-availible-for-thisthanks-in-advance
