it's interesting that they don't generally interfere. One guy on this forum told me that pointed directly at each other at 5cm he got some interference.
I built a 2D lidar system using 9 sensors around a half circle.
https://www.st.com/content/st_com/en/products/embedded-software/proximity-sensors-software/stsw-img017.html
STSW-IMG017
2D LIDAR using multiple VL53L1X Time-of-Flight long distance ranging sensors
And there is a youtube video you can watch. Go to youtube.com and search for VL53L1X 2D lidar.
The sensor does not use much time between ranges to 'compute'. I'd consider that negligable. The I2C transmission of the resuts takes longer.
But it does take two separate ranges at different pulse timings. (Done to prevent Radar Aliasing -which you can Google.)
Those two ranges are going to give you different answers if you are moving. And you will get an error code. I'd consider this code a warning and ignore it.
The distance you get will be the distance at one of the timings.
Good luck.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
